Notice: Undefined index: LatestPoster in /var/www/vhosts/fredmiranda.com/httpdocs/forum/functions_2021_i.php on line 1852 Landscape Photographer - Photography - FM Forums
Here are 2 panos from Spider Rock Overlook at Canyon de Chelly NM. Trying to decide which I like best - wide or tight? So I thought I would throw both out there and see where the opinions go.
Hope you enjoy!
Dave
Thanks for the comments and inputs. Very informative and interesting. I believe I like the tight comp a little better as well but on location I was more drawn to the beauty of the wider expanse. However, as I think about it I think the two canyons intersecting at Spider Rock is a stronger composition.
eriet30 - NM, in this case, stands for National Monument. Since New Mexico is next door, I can see how NM could be misleading.
Dave
harshaj1 wrote:
Both are very good and it is hard to decide but if I had to pick one it would be the second.
Harsha
JimKied wrote:
What Harsha said. I like the second better as well, but both are good.
Gary Clennan wrote:
What a grand view! #2 is my favourite.... Wow.
lostinjapan wrote:
The second one is my favorite. The tighter crop just works better.
Ryan
fingerda wrote:
I too vote for the 2nd, but both are great,
DaveF
kwilliam8 wrote:
Dave, these are both really great! If I was forced to make a choice, I would pick the second.
Keith W.
eriet30 wrote:
I like the subject in number one but number two pops better for some reason.... also its still in AZ not NM
Aztatlan wrote:
The 2nd for me, also. The light on the rocks is nicer and I prefer it without the little grey bush in the corner, although the sky is better in #1.
May 14, 2016 at 11:26 PM
With that sweet light it's hard to go wrong with either shot. If I was to add my 2 cents, I would actually prefer an in between shot. Basically #2 but with a bit more on the left to really let the canyon on the left breathe a little more. Also, I wish there was a little more head space at the top.
But with that said, I would be happy to have either of these shots as my own.
I'm also in the #2 camp - with a slight edge to see a (slightly) more expanded view - if possible. I do like #1 - but the white-ish bush keeps yanking my eye.
I like number two much better. Either it's processed better, or it has nicer light. In any event, there seems to be more detail. I would possibly have turned the camera to the left just a bit until more of the spire on the far left showed (like in #1), but no further than that. Actually, the more I go back and forth, I think #1 just needs to be brightened a bit, then I would like it best.
Hi Dave,
Very nice images you captured. Both are great in colors and details. Would it be possible to combine both images into one? Some how I feel that these were the shots you had a panorama in mind. If I choose one, then the second image would be the one with better composition. But both are nice, again.
Kee
Jim
Jim - maybe that's my quandary. #1 is too wide and #2 is too tight. Sooo - what I did was crop #1 (its a 4 shot pano so I have pixels to spare) to give more openness to the upper canyon and it also allows a little more sky into the pic. I posted above. thanks!
Scott Kroeker wrote:
#2's light with #1's composition.
Thanks Scott. It may be time for a luminosity mask!
Claude wrote:
Really nice shots! I would print both!
Claude
Thanks Claude! It's almost time to fire up the printer!
Brian Woolf wrote:
Beautiful photos, both of them and such nice light! I do like the expanse of #1.
Brian
Thanks Brian - I agree. This is one of those vistas where you want to capture it all.
tmiller9 wrote:
Dave;
Todd - if yanking your eye is a bad thing then I took out the white-ish bush! :-)
Rajan Parrikar wrote:
The second image is marvelous. Beautiful light, excellent composition.
Thanks Rajan! Glad you like it.
Craig - thanks! I like the towering spire in the left of #1 as well. I wish #2 had more to the left (actually I do have it captured) but then to add to the left requires taking from the right in order to keep a 16:9 projection. That's my quandary. In any case I cropped #1.
Kee Woo Rhee wrote:
Hi Dave,
Kee
Kee - I do not think I can combine because they were shot with 2 different lens at 2 different focal lengths. However, a new crop of #1 I think captures some of your suggestion.
